Jim Dockery
Great first birding lens and super telephoto. Lens made for Sony A mount comes with Sony LA-EA3 converter for FE/E mount, Lowe Pro lens case, and Arca compatible plate on tripod foot. All in mint like new condition.
Capture the power and beauty of wildlife, birds, travel destinations, and exciting sports action close-ups with this high-performance 150-600mm long-range zoom. VC (Vibration Compensation) and USD (Ultrasonic Silent Drive) enable you to shoot crisp images of fast-moving, distant subjects handheld, while proprietary Tamron optical technology, including eBAND Coating, works to suppress flare and ghosting for impressively clear, vibrant images. Three LD (Low Dispersion) elements are effectively deployed to correct chromatic aberrations, a challenging problem when shooting at long distances and at long focal-length settings. Tamron's eBAND Coating and BBAR (Broad-Band Anti-Reflection) Coating help suppress flare and ghosting for class-leading image quality.VC (Vibration Compensation) is Tamron's proprietary image stabilization system. Tamron's VC is a three-coil system, whereby three driving coils activate the shake-compensating VC lens group electromagnetically via three ceramic ball bearings. The quiet high-torque USD motor ensures a speedy and accurate autofocus response. This new coating technique developed by Tamron deploys a Nano-structured layer (1 nm = 1/1,000,000mm) of ultra-low refractive index, with dimensions smaller than the wavelengths of visible rays of light. This Nano-structured layer coupled with the sophisticated multiple layer coatings underneath, yields significant anti-reflection properties, efficiently reducing undesired flare and ghosting to an absolute minimum to deliver sharp, crisp images. While covering a very wide range of focal lengths, this lens is remarkably compact and accepts 95mm filters. Its stylish design with signature Tamron tungsten silver finish and elegant brand ring incorporates a sturdy tripod mount to enhance both stability and ease of use. Moisture-resistant construction helps prevent moisture from penetrating the lens.
One of the first shots I got with the lens.
