This is just going to be a rambling story of the ideas I am contemplating. My goals for improvement would be as follows based on my Canon 5DSR
- I want to stay in the same system and use or at least start off with my current excellent lens set.
- I specifically want mirrorless, tilt screen wifi, blue tooth and some of the new focus aides.
- I hate losing mpixels, but 45 is probably enough.
- I want better DR and high ISO noise improvement. I wonder if the heat management system used in the EOS R5 will help in long shutter heat and noise.
- Less weight will always be welcome.
- A 24-105 would make an ideal all around lens. But I have the 11-24 F4 and 24-70 f2.8 which are excellent.
- I don’t need video.
- The only thing my current system is lacking is good night photography. The rest is just convenience. I am not dedicated enough to night photography to buy specifically for that purpose, like for example fast wide lens. My 11-24 is a great night lens because at f4 it does not need to be stopped down any further for DOF, and is wide enough to shoot at a longer shutter and lower ISO for the same exposure. An f2.8 lens probably needs to be stopped down for DOF.
- Also it occurred to me that I like the Milky way core and don’t need the entire arc, so 24mm works for that, and is sharp at f2.8 and if I have nothing close does not need to be stopped down.
- Also, I want as bright a moon as possible to get some natural light on the landscape. To test this theory, I went out last night for some Milky Way under a ½ moon. This test failed as it was too bright for the MW to show up. But I have done this with a slightly dimmer moon at The Temples of the Moon.
- Here is an example of last night test. Too bright for a Milky way and way too noisy.
